I would like to replace the relay which triggers a water pump, with a relay which times out after, say, 10 minutes. And if it times out, it stays locked out until reset.
Needs to be 230v AC on both sides of the relay.
If it doesn't time out, the next time it's triggered it should come on normally.
I've spoken to everyone from RS to Farnell, and they have everything but. I even found a specialist called Quasar who were very helpful, but again, had everything but, although these came close... https://quasarelectronics.co.uk/Category/kits-modules-multi-mode-delay-timers
I've got about 10cm by 12cm space to replace the relay currently inside the box.
Some pics here: https://photos.app.goo.gl/18RiWUcP5Hz9dCo29
Yes, I know I could probably roll my own with an Arduino, but if it all went wrong, not sure what the insurance would say!
I've posted more on the plumbing side over in this thread if you're interested in the application.
https://www.diynot.com/diy/threads/problems-with-float-switch-in-header-tank.509127/
