Siemens rwb1007
24 Sep 2018
What press on rwb1007 to set a reading currency temperature from thermostate , example heating is on to 22 deegres and when is 22 is off and If is less than 22 is automatically on .
I hope you understand me
Didn't understand your post ,but if you are trying to get your rwb to tell you what your room temperature is ,it cannot do that.
I have set 22 on thermostat but heating is not off when I already have 22 in The room and still heat
If you lower the thermostat ,does boiler then switch off ? The rwb has nothing whatsoever to do with temperature control. Its the thermostat that does that. All the rwb does is turn the system on or off at the set times.
Yes , but after 1 minute switch on again and All The Time heating.
Boiler is off If i hear click on thermostat
Do you mean the boiler continues to burn gas when you turn thermostat down to ,say 5 degrees ???
I would like have on 24 hrs and will heat automatically when temp will be lower than 22 °
What boiler do you have ? Sounds like your thermostat is not working.
Thermostat is brand new and boiler too. Heating engineer connected all of them but i changed house after and didn't see how he did it
Logic combi 30, programmer siemens rwb1007 and thermostat Drayton combistat rst8
Then it is all under guarantee and you should call the installation company back to resolve the issue.
