mrcrow - be advised that all of these suggestions are notifiable work:
I guess you could convert it to a b25 if you can get one.
Or convert it to a ring
MCBs are also available in 20A or 25A versions, both of which would be suitable if using 2.5mm² cable.
The shower unit appears to have a spare way for an additional circuit, depending on the rating of the RCD in it.
Remove the entire lot and fit a single new consumer unit for everything.
Hadn't spotted that spare way! See if you can get a 25A mcb for it. (may not be easy!)
I guess you could splash out on some 6mm cable and use a genuine 32A sector MCB.
