Hi, I was loosening my sockets for decorating and upon loosening one of the sockets there was a loud pop and bright flash and sparks flying in my face, it turns out one of live cables of the ring had slipped out its terminal and shorted against the earth bar. This tripped the 32 amp circuit breaker but it did not trip the rcd which has got me a bit concerned, It was definitely a live to earth short circuit as the backbox had blackened and a scorch mark where the wire had touched the earth bar on the socket.
Why did the rcd not trip? I can understand an rcd not tripping on a live to neutral short as there is no imbalance but surely it should have tripped on a live to earth short as this is obviously an imbalance? Could it be that the fault current was so high that the mcb reacted first before the rcd had a chance to operate?, or could it be a more serious problem.
The consumer unit is made by hager, if that helps, the rcd is just the standard 63 amp 30ma.
thanks.
Ps yes I know i should of had the power off but I had no intention on touching the terminals, just loosening the socket plate for painting.
thanks.
