Recently had a bathroom re-fit and ended up with the shower not working properly.
The original shower was fitted 20+ years ago. This has been put back. Before re-fit, there was what looked like speaker cable running from the shower valve to a pump (pump by hot water tank in airing cupboard). It no longer does. I guess the cable carried an on/off signal to the pump when the controller was operated (?) Power to the pump was permanently switched on at the wall.
We now have a new installer who can’t figure out how the cable should be reconnected at the shower valve. And he says the set-up was non-standard anyway. I can see he maybe has a point - modern pumps mostly switch on when a drop in pressure is detected when the valve is opened. I think. Anyway no cable right?
Anyone come across a set-up like the above? Grateful for any comment.
Btw the way things have been left, the pump kicks in when switched on at the wall by the tank, regardless of whether the shower valve is open. Don’t like the idea of the pump operating with the outlet valve shut.
