Floating shelf/breakfast Bar
10 Jul 2016
Hi just wondering if anyone could help please. I live by myself and have gotten rid of my table and chairs because they are not being used. I’ve always wanted a floating shelf/breakfast Bar and plan on getting this
https://www.homebase.co.uk/solid-oak-hobbyboard-1150-x-300-x-18mm_p423161
Just wondering if it would be difficult to have this on a floating shelf And if so could you recommend good ones? Many thanks
Unlikely to be strong enough, weight on it could snap the staves if unsupported.Better to use kitchen work top with a leg under it.
It got ,not gotten, no such word unless you are a yank?
This is what I was thinking about
One in pic is around 30mm thick , suggested fixings you linked too require 15mm hole in your 18mm shelf? Leaving it supported on less than 2mm of timber .?
You might be able to use something like these with shelf trimmed to required thickness.
I assume you have solid brickwork to fix to?
So basically there’s no way to hang an 18mm with 300mm depth shelf then? That sucks was really hoping I could I like the floating look rather than brackets
Thanks. Pity they don’t do 300mm depth 200mm may be a bit short
Got a hobby board from HomeBase and a few brackets.
Two options for a strong "floating shelf"
In a thin wall if space permits use a bracket on the other side of the wall to take the twisting load of the pin in the wall. Either just pin and bracket or extend to have a shelf on both sides of the wall.
Or as in my kitchen, wrap the shelf round a corner.
Cheers. Tbh I don’t mind the brackets. I have three and they are going into a really sturdy brick wall so it’s extremly sturdy.
--non-DIY post--
Actually it is an English word first used in the 4th Century and used by writers, poets and playwrights throughout English history since. The Victorians changed that though, calling it an "Americanism".
Another thing the Victorians did (when attempting to standardise our language) was drop the use of 'z' in some words such as in "organize" or "appetizer". Before then and for many centuries before that, we used 'z' in place of 's' and it was only around the turn of the 20th Century that current spellings in the United Kingdom became common. In short, the use of the 'z' has nothing to do with America -- they are merely using the spellings we took over there in the early days of colonisation (or colonization).
--non-DIY post over--
