But John I, and other gasmen as well as Joe Public, are not refering to the gas supply pipe, nor any water supply pipe that feeds that service from the main network into the property, we are refering to the INTERNAL installation of pipework be it gas, water or, as you just mentioned above oil. The electrical regulations, as written would seem to require require the internal installation of metalwork used by those services to be bonded together as near as to the point of entry to the building.
as the above diagram.
Those same regs require central heating pipes to be bonded together also. Not many people have central radiators outside (but there are occasions where drain valves are).
Oh and that other old bone of contention from electricians is where plumbers still insist on linking taps and sinks/baths together with a bit of earth wire. Blame electrical regs again.
