hi all,
Putting in a hatch to my man cave in the garage loft that opens on hinges to one side, looking to make the hatch more like a door than a simple flap and as such wondering how much clearance is suggested.
The frame for the hatch is 1000mm by 750mm (with the hinges down the long side).
The door is going to be 95mm thick (there is a lip and this makes it fit level with the floor). So the simple question is how much clearance should I leave along the edge (Read something like 5mm for a normal thickness door but the thickness of the door would increase this I would think, so maybe make it 740mm wide?!
Also because the floor (around the frame is 20mm thick chipboard, and am looking at the hinge opening at floor height, any suggestions on hinges? (Normal door hinges would have the screws passing too close to the chipboard), would back flap hinges suffice?!
