Has anybody come across a one gang socket outlet with a single USB socket (with or without a 3 pin square socket)? Nearest I can find is a one gang plate with 4 x USB's but a bit pricey at £23 + VAT.
My daughter wants to plug in a NEST wireless thermostat - which still needs a wired power connection. This has a power cable with USB both ends. The idea was to put this on the living room wall (it has a wall mounting plate) with the USB cable through the wall to a socket on the other side - but there is only room for a single socket. Ideally it would be USB only then I can wire it 6 amp from a lighting connection but could use an intermediate FCU if need be.
Grateful for ideas.
Grateful for ideas.
