Expanding foam with plastic pipes & cables
14 Jul 2016
What is on the web appears many years old. Are foams safe with plastic pipes and cables?
The manufacturers of polyurethane expanding foams appear to say yes. I can't speak for pipes, but I've certainly had PVC cables in contact with such foam for many years without any apparent ill effects.
It would be interesting to know if there are any adverse affects on barrier pipe, Speedfit, Hep2O, etc. If so, how long would it take for the pipe to deteriorate. The same with cables. It may take many years (10-15?) for the foam to take affect.
If there are affects, I would suspect plastic pipe to be affected more as it expands and contracts more than cable - and leaks.
From my (albeit fairly limited) understanding of the chemistry, I don't think there is any real reason to think that there will ever be any harmful effect, since, once the solvents have gone/evaporated (which happens early), I think polyurethane foam is pretty inert - and, being essentially a closed-cell foam, has little ability to absorb anything.
It's a different matter with expanded polystyrene foam (sheets of which used to be used as insulation), long-term contact of which with PVC cables can result in leaching out of the plasticisers, leading top the PVC cable sheath potentially becoming brittle. However, I think that even that takes a good few years.
Expanding foams are not safe with plastics, see the picture.
The foam makes the plastic brittle on the water fittings causing leaks. Avoid using any foam.
The fitting had to be changed as it was dripping water through into the ceiling.
Even I did not think it was possible for foam to damage a plastic fitting!
Using foams is very messy, if you have gaps that need to be filled just use rock wool.
People like expanding foams as it is easy and enjoy pressing a nozzle giving them a sense of control!
I would avoid any use of expanding foam on any plastic, you can see the foam has eaten away at the Hep2O fitting. The effect to rot this away was over time.
Expanding foam is only useful for masonary gaps and filling in gaps in PIR board insulation.
Hope this helps
Hope this helps
I haven't come across that before.
I know that acetone is a solvent for expanding foam but I would expect that it once the foam has cured, it is stable.
