Hope you guys can advise.
We are having a complete renovation in the kitchen / dining room where we've just had a load bearing wall removed. We want an electrician install 3 or 4 rows of spots running one end (kitchen) to the other (dining room)
You'll see the plasterboard pulled back for the load bearing steel, which with a torch you can see all the existing cabling along with pipe work for both rooms (handy)
The ceiling is going to be over boarded and plastered.
What's my best practice here?
1. Get the sparky in prior to over boarding the ceiling so he can see what is what and mark up, prep and drop some cables and then get it over boarded? etc.
2. Or just get it all plastered up and let the sparky crack on later? Which I assume pulling the upstairs floorboards up?
Only problem with Option 1, I'll want some of the spots where that big gap is. I suppose I could cut some boards up, fix with some plaster boards screws so they can be unscrewed later when the sparky drops his cables.
I hope I've explained everything and that reads OK.
Thanks for looking!
Thanks for looking!
