separate zones in heating system
Hmm yes thinking about it more that radiator sounds like it is already effectively zoned off rather thank being on a circuit with other radiators. In which case a smart TRV would work.
Tado is pretty good value, a base control thermostat in the main house and 1 smart TRV for the garden room would be about £200 and very simple to install.
The Wiser system is cheaper for the start up system of the control box, room stat and two TRV's at £200. Plus additional TRV's are only £40 which are the cheapest available.
The Tado system needs the room stat to be wired in permanently, but the Wiser room stat does not - which is why I went for Wiser. But Tado is a bit more polished and established. Otherwise the two perform the same.
We may be a bit OT now though
Actually the Tado room stat can be wireless with the Tado Extension kit. The extension kit plugs in place of a programmer, and the thermostat can be anywhere.
Can't believe that OP has no thermostat for the house. Very strange setup with the zone valve too.
It may be wireless for the connection, but does it need hardwiring for power?
