H
Hot&Cold
most gas boiler repair companies expect the system to be installed correctly,thats why they send part changers
I fully agree with you re: wiring centre If I knew what I was doing with a multi meter I’d have a prod around myself.Surprised BG havent pulled out the third party interference card yet!
I should think that there is a issue within the wiring centre thats occured at some point during all these valve changes. Its really not a massive job to rewire the airing cupboard.
And some people just like to have a dig on the internetmost gas boiler repair companies expect the system to be installed correctly,thats why they send part changers![]()
Thank you Dilalio. I’m stumped - as even Vaillant, the boiler manufacturer has confirmed that the installation is fine. I will post the full details of the fault when it’s found!To be fair. Every now and then along comes a problem that stymies everyone... Especially with electrics and its just far easier to take it all out and start again.![]()
AGREE!!!!!!So many have given you the correct answer, it is not wired correctly
I think you mis understood the Vaillant engineer, what he said was the boiler is fine, he would not look at anything outside the boiler its not why he is thereThank you Dilalio. I’m stumped - as even Vaillant, the boiler manufacturer has confirmed that the installation is fine. I will post the full details of the fault when it’s found!
Hahahaha!!! I’ve learnt all this from google and replies from you good folk on here!Judging by the correct terminology you've been using, it sounds like you're almost qualified to do so after all this![]()
it has been installed as a 230v 3 wire installation, without pump overun. The old boiler was merely taken off the wall and the new one put up - using the same existing cable
Yes - apologies i didn’t explain it properly. Vaillant engineer checked how the boiler has been wired up (wires inside the boiler near the pcb). You are correct - he did not check the wiring in the junction box/valves etc.I think you mis understood the Vaillant engineer, what he said was the boiler is fine, he would not look at anything outside the boiler its not why he is there
Hi. I’ll post a pic from the Vaillant installation booklet (the Vaillant engineer pointed this out to me and confirmed this is how the boiler has been installed.Don't want to disturb this fascinating thread or send it off on another tangent. And I realise that this is nothing to do with the OP's problem, but is the boiler correctly installed without having pump overrun? I thought it was needed on modern boilers to protect main hex?
Am prepared to be corrected.![]()
Vaillant have been out and checked the boiler. - they have confirmed that all is fine with the boiler and the wiring. it has been installed as a 230v 3 wire installation, without pump overun.
Once this saga is over, I will have the pump run permanent live connection installed - but just darent at this stage with the major issue we are already having.
