Just had a minor disaster. What did I do wrong......
Three fixings into a Cotswold stone wall, very old wrought iron nails plus/minus 3/8" square section and 4-5" into the wall. Fixings for an old hardwood door frame 4" square.
Drilled the holes oversize finishing with a 3/4" drill, dusted out thoroughly.
Did a dry assembly to ensure everything was aligned and the holes deep enough.
Using Anchorfix, one of those two-part resins that comes in a tube, with the fancy nozzle that mixes it.
Filled the holes nearly to the top, expecting any surplus to ooze out as I tapped in the nails. I've used it a couple of weeks ago for hinge pintles into stone, no problem.
Two nails went fine, the nail just went in, although nothing oozed out and I was thinking I might not have used enough resin. But the last one, ironically the thinnest, refused when it was only a couple of inches inserted.
Assuming I might have mixed the nails - they were similar but not quite the same thickness - I decided it must be tight in the wood so I whacked it, went in a bit more then stopped, so I whacked it harder with a 2lb mallet.
Crack!! the stone split. A big stone, about 2 x 1 x 1ft.
So, it seems I had a hydraulic lock. But how on earth does that happen, there was plenty of room for the surplus resin to ooze back out of the hole, and the nail had only gone 3" into a 5" hole.
I'm worried now, the stone is split and the antique nail is lost, I'll have to cut it off.
A lot of work has gone into this job, and I have three more fixings to do.
Where did I go wrong?
V8
V8
