Roof tile
cut.trim the foam to shape of the underside of tile, as it is, it will track water in.
Then show another picture
Dont drill the flashing , You would be better off drilling through the two tiles under the head lap.
The screw would be weathered by the tile above
Not trimmed the foam yet as waiting until I figured out what to do so do you mean drill I hole through overlap and put in a nail to hang it?
We glue all our slither cuts to the neighbouring full tile using a polymer type (Stixall, Sticks like S**T, CT1, Gorilla grab, etc) adhesive.
Think glue is gonna be the way to go what is gonna stick it solid
You need to trim your foam as Data has said. Use an uber sharp Stanley. Be aware of the tile profile and the way it rises or falls before you trim.
Sometimes you need to glue them together away from their final resting place - other times each subsequent course holds the glued bit beneath, in place.
As above, I used stixall on mine last year, no issues since. Comes out like a clear silicone but goes rock hard very quick. Can’t see it ever failing tbh. Even took my weight when I accidentally stood on it.
Thanks very much gonna get some tomorrow and give it a try how long did it take to set and we’re they cement tiles?
They were concrete tiles. No idea how long it took to set, Felt firm after maybe 20 mins but I guess it took a lot longer to fully go off
