- Joined
- 9 Jan 2019
- Messages
- 4
- Reaction score
- 0
- Country
Please can someone tell me if this new digital thermostat can be fitted ?
He's got a neutral, right there in the photo. What he may not have, is a permanent LiveI'd say no based on the info so far, but you'd have to look at the other end of that cable to see what each wire is assigned to do.
You need a neutral, and you need your heating to be triggered by a normally open on off demand signal.
Use the earth unless it’s twin and earth as hard to see?He's got a neutral, right there in the photo. What he may not have, is a permanent Live
I agree that he's got a wire identified by blue insulation, but that could mean anything especially in a 3C+E with old colours. None of those wires are sleeved in brown or red as they should be (assuming not the unlikely event it's a three phase Delta appliance) so i can assume the person who fitted it wasn't fully up on the regs. I wouldn't advise the op to assume it's neutral without some testing first.He's got a neutral, right there in the photo. What he may not have, is a permanent Live
Correct as there's no actual insulation on it.It’s twin and earth so I wouldn’t. (Some might)![]()
However judging by the wallpaper it probably has plasterboard so it may be feasible to pull through a flex
Oh yeah good point i was too distracted by the wallpaper to notice the trunkingyou don't think that the trunking underneath might be easier to use?
Was thinking this myselfNot only does he have a wire identified by blue insulation, but it is also connected to the neutral terminal on the existing thermostat. I'd say there's a pretty good chance it's a neutral![]()
