I`m just about to replace a radiator in my hallway , but not sure which pipe is flow , and which is return . The current rad has 2 identical valves , with no thermostat .
Ive tried holding the pipes when the heating kicks in to see which heats up first , but there doesn`t seem to be much between them . Its a vertical type rad , 450mm wide , by the way .
However , I have noticed that after about 15 mins , the left side of the rad is considerably warmer than the right . Is it safe to assume that the left is the flow , side ? I`d rather avoid taking up any floors to investigate further , if possible .
Thanks , Colin .
Thanks , Colin .
