House refurb - changing gravity fed system to combi
Status
Not open for further replies.
1 Dec 2007
Hello we are buying a house and the current setup is tank in the loft and electric heater for the hot water. Central heating is gas.
The setup is the original one from the 1980s.
We would like to update the system to a COMBI boiler and I was wondering whether we should also get the existing central heating pipes changed. I read somewhere that when a system gets switched to Combi sometimes the existing old pipework can leak and it makes sense to replace this too. We are replacing all the radiators anyway.
any thoughts would be appreciated.
Regards,
Is a combi the best option for your new house ? A hot water cylinder and a non combi ( but condensing boiler ) might be the better option as regards hot water supply.
As a suggestion, get the installer to pressure test the system to, say, 3.5 bar. This is half a bar over the maximum it should face with a combi, even in fault circumstances. If it can take an hour, or longer if possible, without losing pressure, then it should be OK in normal use. Replacing the pipework can be quite disruptive, particularly if you have tiled or laminated floors.
As bernardgreen has asked, is a combi the best solution for you? Have you had the water main pressure and flow rates tested to see if they are adequate for a combi? How many bathrooms? most combi's are not that happy with more than one hot water outlet being used at a time, although there are exceptions.
many thanks for the replies.
we are not really happy having a tank in the loft that
is one of the main reasons for having a combi system.
You don't need a cold water tank in the loft if you have a non-vented hot water cylinder. The radiator system can be pressurised and that removes the need for an F&E ( feed and expansion ) tank in the loft.
quite a few home owners and tenants are not that happy with the limitied flow of hot water from a combi boiler.
those are not the only two alternatives.
How many bath/shower rooms are there?
if the system is pressurized would it mean that old pipes from the 80s install are likely
to be a problem?
You most likely have 2 tanks in the loft, a cold water storage tank and a smaller F/E tank for the heating. Do you want to get rid of both?
yes that is a non negotiable with the other half...
she worries about leaks whilst being away. one of our friends had a massive flood due to tank burst.
could i keep the original heating pipework with this combination or will it have higher pressure than the pipes can currently take?
Hard to say, I have known people who did have leaks when they converted to a pressurised system from a non pressurised ( tank in loft ) system. Others didn't have any problems with leaks.
Status
