I suppose it would with 90%, but what would you do with 70, 60 or 50%?
As I said, it's when one has those 'intermediate' probabilities, that that then raises the $64,000 question.I suppose it would with 90%, but what would you do with 70, 60 or 50%?
And in practical terms, had they been fitted beforehand I would have expected the outcome to be unchanged - the SPD would not have helped in the least. As suggested, there was a (common mode) surge induced into the cables to the lights which the controller couldn't cope with. As you were able to discern a time lag between flash and bang, it wasn't a direct strike - given the rise time of the current in a lightning strike, protection that far away from the device would be worthless due to the inductance in the cables.Those "Over Voltage Arrestors" were fitted to that CU after the following "event" :-
Why will they?I would imagine there's scope for a fairly rapid decline in cost once they become more commonplace given the minimal number of parts inside.
I would hope that they won't ("become commonplace", unnecessarily), but I fear that aptsys may well be right, and everyone knows the reason as well as I do. Not installing them requires thought and a sensible/intelligent judgement, but fitting them can be done mindlessly. Worse, it will probably snowball - as the number installed creeps up very slowly, those of limited confidence will become increasing nervous about a decision not to install them, so the rate of installation could start rising rapidly. Then, of course, if the number being installed gets past some threshold, 'pre-populated' CUs which include them will probably start appearing on the wholesaler's shelvesWhy will they?
Nobody unwilling or unable to do that should be working as an electrician.Not installing them requires thought and a sensible/intelligent judgement
In an ideal world, anybody found to have done that would have his ability to work as an electrician taken away from him., but fitting them can be done mindlessly.
Nobody lacking the confidence to make proper judgements should be working as an electrician.Worse, it will probably snowball - as the number installed creeps up very slowly, those of limited confidence will become increasing nervous about a decision not to install them
Indeed so!Yes, you are right - people who can't or don't want to think things like that through shouldn't be doing the job. But as we all know, there are a heck of a lot of people who really don't seem to even know that these questions are there to be considered.
Hmmm. It must be a few years since I last told this story here - so, if only for the sake of newcomers ...As an example of the level of knowledge amongst some people ... He was 110% adamant that he could not put the power cables in the smaller top section - they must be in the middle section as the insulating barrier only works one way. WTF![]()
Who won?I had a very heated argument with an 'electrician'
Well, he remained 'adamant' - but I sacked him (there were other reasons as well!) - so, in one sense, I suppose I won!Who won?
And sadly...
Is it like the police?
Does society get the tradesmen it deserves?
