The flue lengths run up to 110m using 3 inch cheap plastic drain pipe, or a co-axial flue - the same used by Ideal.
That and the ability to suck 40kW through god knows how many meters of ½" pipe make these boilers a wonder of the modern era @Grumpy Gasman. I certainly won't bother spending £400 on a flare stack to test a gas supply on a project and just tell them that the 10:1 turndown ratio will compensate for the massive overkill on DHW as the alternative of digging up huge swathes of courtyard and a blacksmiths workshop if the gas supply is undersized will be unnecessary.
All hail Hard-On and the Koreans.
