Hi Everyone,
Someone has attempted to gain entry to my house by standing on my 40mm waste pipe from my kitchen sink which comes through the wall as a straight pipe, immediately bends 90deg and then runs down to the soil stack.
In true bad luck fashion it has broken right on the 90deg elbow which is solvent weld so my plan was to cut the horizontal half way and then remake the pipe back into the kitchen sink trap.
The issue is the pipe seems tight in the wall as expanding foam appears to have been used. It is also obscured by the kitchen unit as the hole the pipe goes through is about 42mm in diameter in the unit!
Is there any easy way of carrying out the removal of this pipe as I'm dreading it
the rest will be an easy job apart from this.
