What easiest way to connect the water supply to the toilet cistern?
The pipe (1) is curved and has recently been cut..
There is approximately 150mm gap between the end of pipe (1) and the cistern entry (2)
When i turn on the water supply water leaks (I presume this is due to the curve in the pipe), what would be the best way to stop water from dripping from the stop end?
Also, the pipes (3 and 4) which are hot and cold pipes for toiler and bathroom are very tight to the wall..
