It’s just been calibrated but the sensor has failed. I was just going to swap it out with a new one which I presume is set to a standard and then check it against another unit in calibrationBizarre question....why would you try an run a business with an uncalibrated FGA.
But when you fit a new sensor you need to reset the unit softwareIt’s just been calibrated but the sensor has failed. I was just going to swap it out with a new one which I presume is set to a standard and then check it against another unit in calibration
where did you get them sent from ?Oh ok, fair enough. I used to drown the sprints all the time and just had new sensors sent out to fit ourselves
My thoughts exactly @kevingesSo Anton are sending you uncalibrated sensors to fit in an instrument, that they know is flooded, to be installed by an untrained engineer with no calibration gases to reset the cal points.
Well that surprises me.
