wiring 2 Pyronix DeltaBell X external sounders
6 Apr 2019
How do you wire 2 Pyronix DeltaBell X external sounders into a ADE / Honeywell Optima Compact Panel 8EP396A. The External Sounder only shows how to wire one.
The tamper return of first unit is connected to the 0v of the second unit ,the return of the second unit to tamper return in the panel , all other connections are parallel
Also recommend putting the jumper of one of the bell boxes to scb setting, this means when they are triggered one will be powered by the internal battery. There is a possibility otherwise both bellboxes pulling to much power and popping a fuse.
I have just wired one of these to mine and I cannot get the lights to work on the bell box.
Just looking at this as putting another deltabell X at rear
Do you still have the link 0v to t
on both boxes
No you wire them in series ….. tamper return from first bell connects to 0v on second unit and tamper return on second unit connects to panel ..
Nah ….just couldn’t be arsed to read the previous thread …..plus not having the patience with older threads that bodge various jobs ….…:rolleyes:
