Hi
I wanted to measure the mains voltage via the power lead that runs to my kettle.
I set the meter to the 250V ac range.
I inserted the black probe all the way into the Earth terminal so that no bare metal on the probe tip was visible, so as to be safe.
When I inserted the red probe into the Live terminal my multimeter gave off a small arc and the RCB tripped ? I removed the probes and reset the RCD without issue - the kettle worked as normal.
When I opened up the rear of the multimeter the circuit card was badly charred and the battery was partially ruptured.
The meter was over 35 years old and I happened to notice that the battery was dated 2006, however it was still working when checking for continuity.
Based on what I have described I think that the multimeter failed which is why the RCB tripped ?
Does this sound plausible ?
Many thanks in advance.
