Replacement cold water tank
Did you mean 100 gallon? That's about 4 baths. I have a 50 gall which is pretty big. Do you have several bathrooms?
Vented hot water cylinders are often in the region of 100 litres, which is about one bath.
Hi John,
No we've only got the one bathroom, but the power shower empties the 25 gallon tank in 7 minutes max. That's fine for me, but not for the other half (plus, the pump objects). So I figure add an extra 50 or be neat and swap for a 100.
Unless you have a huge cylinder, the hot water will run out sooner.
Hi John,
Yup, obviously you're right. But I have roughly estimated the HWT at 95l; as the shower's cold feed is coming from the header tank, I'm surely going to need 200l as an absolute minimum?
Hi John,
Well.... if you're replacing the HWT then you might as well go unvented, get rid of the CWT in the loft altogether and replace your power shower / pump with a standard thermostatic mixer ?. A bit more expensive but a better solution IMO. Just an idea.
Hi wwwebber, just the cold tank being done; which is cheap and cheerful.
ok, cool. As another poster has said your HWT needs to be up to scratch too. No point having a larger CWT if your hot water then runs out :)
