Bathroom fan help.
7 May 2017
Hi all, many thanks for the previous asistance on these forums.
Got An internal bathroom.
Ok.does any know if there is a bathroom fan avaiable that will run at full speed when the light is switched on But revert to half speed when the bathroom light is turned off. ?
The idea is for continous reduced ventilation in a flat with no windows.
The current fan is a 4 inch spigot.wired with a permanent live,switch live, neutral & earth.
Tia
Mistake - I thought the first item was a trickle fan.
Never a lie, and the mistake is now corrected, so you can remove your allegation.
You're so busy running around trying to cause trouble you lose track. And I can do what I want not what you want.
I'm not trying to cause trouble.
So are we to take it that you are not going to withdraw your false allegation that I knowingly wrote something untrue?
Why should I or anyone relieve you of your embarrassment which is self inflicted by your constant desire to spread discord throughout this forum.
Get over yourself and stop whinging
