I had a Whirlpool ACM 822 / NE induction hob installed over a year ago, with its supplied cable. The instructions are as follows:
Following an electrical inspection, the electrician has informed me that the supplied cable is not acceptable for the required load according to regs.
The hob is rated at 6500 W (electrical connection rating). It is on its own 32A MCB circuit. The cable is connected as above to the cutoff switch, and from there on standard electrical cable to the consumer unit.
I understand that the cable supplied is 2 x 2.5mm2 = 5mm2, and 6 mm2 is required. EDIT: My mistake, cable is 1.5mm2. Apologies.
The electrician has tried speaking to Whirlpool but got nowhere. Has anyone come across this before? Is there a solution? This hob is sold in the UK with this particular cable and was installed by the vendor as per the manufacturer's instructions, so I'm puzzled as to how this can be permitted.
Thanks for any suggestions.
