- Joined
- 30 Jun 2019
- Messages
- 7
- Reaction score
- 1
- Country
I've been reading this forum for a while, but I'm only now braving my first post. I was hoping someone may be able to advise?
I'm building an ensuite in my master bedroom which warrants a new soil stack on the side of my house - the existing stack is on the other side of the house and isn't really feasible to connect to. My house uses a combined surface water / foul water sewer. The manhole cover is out the front of my house and is shared by my neighbouring 2 properties. Consequently a soil pipe cut across my front garden to my neighbours and happens tee off to serve my down pipe on the front corner of the house. This is the underground pipe I was planning to tap into. I would be running approximately 3m of pipe to a new soil stack, that would then service the ensuite.
The issue I think I'm facing is that the underground pipe directly connecting to the existing down pipe is only 18cm below the surface. When installing the new soil stack 3m away including a fall of 1/80 (3.75cm), I don't think there will be enough depth (18 - 3.75 = 14.25) to install a rest bend under ground. Some of it would protrude above ground.
My questions are:
I've read over the building regs about drains and can't really work out these things.
https://assets.publishing.service.g...achment_data/file/442889/BR_PDF_AD_H_2015.pdf
Any help would be great!
My questions are:
- Do I have to use a rest bend? or can I use something else more shallow/shorter? A normal 92.5 deg bend?
- Is the drain so close to the surface allowable? If so, do I have to cover it with something?
- Are there any other options to connect to this underground pipe (bearing in mind the new soil stack is planned to be situated next to an external chimney breast making it difficult to move the soil stack closer to the existing pipe)
