I will be building a "summer house" in the back garden and am undecided on whether to use grey aerated blocks or insulated timber?
I want it to be warm as well as pretty sound-proof since I might consider using it for music mixing/mastering.
The grey blocks would be single skin 100mm thick + 50mm thick studwall/celotex insulation + 12mm plasterboard and skim coat.
If timber it will be 18mm exterior plywood + 100mm studwall with 100mm celotex unsulation + 12mm plasterboard and skim coat.
Which one of these 2 would be better for sound and heat insulation?
The timber is on order already so need to make up my mind soon on whether to cancel and order grey blocks instead. Quote for materials came back much higher than I originally though (£1300+) so I'm thinking at this point is it even worth going for a timber build
Add to that the plastic cladding which will push the price much higher for the timber build... but am planning to do that at a later date.
Thanks in advance.
Thanks in advance.
