My Architect has specified 140mm blockwork over the top of my 6" timber kit extension. My builder says this is crazy and that we should use only 100mm blocks. He tells me that he knows the BCO and will talk to him to see if it's okay to use 100mm blocks.
The garage we are knocking down to make the extension is made from single skin 140mm block, with an internal 100mm block wall between garage and utility. To me, the 100mm block loks helluva thin to make a two storey extension, and all our comlpeted (approved) plans and heat loss calcs say 140mm.
Is it normal practice to use 100mm block on a timber build, and is a "word with the BCO" all we need to make the change. I'm guessing this would probably impact the heat loss calcs as well as the plans.
Apparently this could save us a couple of thousand quid (switching from 140mm to 100mm block), but the last thing I need is to build it with the wrong blocks.
Obviously the 140mm is more substantial, and I'm curious if it would give us better noise insulation as we are next to a busy street and the rooms will be bedrooms. I'm in two minds whether to pay the extra and use the wider block, or save the couple of grand and use it elsewhere in the project.
thanks
Any advice greatly appreciated.
thanks
