- Joined
- 9 Jul 2019
- Messages
- 3
- Reaction score
- 1
- Country
Hello all,
I'm in the process of up-cycling a piece of furniture which appears to be made from particle board with some kind of veneer coating. I sanded the whole piece, vacuumed and then wiped down with a damp cloth.
Then it came to painting. I opted to go with Leyland acrylic primer/undercoat and the Leyland Acrylic Eggshell top coat. After 2 coats of the primer/undercoat I had some horrendous bleed through coming from the sanded veneer and so as I've had some success with Zinsser 123 covering stains previously, I applied a coat of this on top. This has made no difference whatsoever. I even tried a second coat on a test patch to see if that would improve things but sadly its just not doing its job.
I was hoping that someone might be able to provide some advise on a product which is known to work where Zinsser 123 fails and that would still allow me to go with the water based Eggshell top coat.
Thanks in advance for any help you can offer.
Crewe
Crewe
