- Joined
- 1 Sep 2015
- Messages
- 377
- Reaction score
- 6
- Country
We recently have part of our garage decked out and converted into a room.
On top of the concrete floor was laid 50mm solid foil backed insulation followed by T&G floorboards with bitumen in between each layer.
There must have been some slightly deflections in the original floor, as in places when you walk over the flooring now, there is slight movement leading to a noise that sounds like when you walk over a plastic floor with wet feet.
Holes were then drilled through the floorboards into the concrete, and concrete screws inserted to just tighten the floor enough to remove the noise.
We've noticed though that these screws now have a very slight damp area around the head of the screw. Does anyone know what this could be from? Condensation build up on the cold head near the wood (it has been recently skimmed)? Moisture/condensation draw from the concrete?
Any suggestions on what to do here? We were going to lay a 6mm subfloor on top of the floorboards with LVT on it, but obviously don't want to trap any moisture in the wood.
