Extending garage roof (only) to extend overhang - PP required ?
27 Jul 2006
I want to extend my garage roof "only" forward to increase the overhang to give a larger covered area, and wonder if anyone can confirm if i need PP.
The existing garage door is shown on the diagram below by the red dotted line. The current up and over garage door will be replaced with a new standard door type and will remain in approx the same place.
The black horizontal line shows the existing roof/overhang position
I would like to extend it forward as depicted by the green solid lines
It will not extend past the front my my house (left) but will need to come forward 1100mm of my neighbors property
Out of courtesy, i will obviously be asking my neighbor for permission to fasten joists to his property, but can anyone confirm if officially, this needs PP please ?
Many thanks in advance
Apologies, forgot to add as i think the height is relevant also, the existing height of my flat roof is 2450mm
Can anyone advise or shed any light please whether PP is required ?
More than just a matter of courtesy I think if you are building on to your neighbour's house :!:
Are there any windows near the front corner of your neighbour's house?
Assuming the garage was original (or was built under a previous planning permission) what you propose would need planning permission as it is an enlargement which extends beyond a wall forming a part of the original front elevation, the 'wall' in this case being the existing garage door.
If the garage was a later addition built under permitted development, the canopy/carport would be permitted development as long as its width was less than half the width of the orginal house.
Thanks for the reply Leofric
The neighbors house consists of a 900mm pillar each side with a single large window forming the rest of the front of the house.
I'm not sure of the complete width of their house unfortunately
Thanks for the reply Tony
In reply to your points/questions :
We have owned the house for 20 years and the garage has not been moved so assume it to be as per the original design or was erected by a previous owner
The replacement garage door will be fitted where the current door is place so strictly speaking the "wall" will be in the same place, its just the overhang/roof that i would like to bring forward
The width of the carport/garage is 2.5m so is less than half the width of the rest of the house
Can you explain why if its original, that it would need PP but if its current position is as per a previous PD, it could be extended forward under PD also ?
It seems the wrong way around to me :confused:
Thanks for taking the time to reply...much appreciated
The rule for enlargements at the front is that it is not permitted development if;
(e) the enlarged part of the dwellinghouse would extend beyond a wall which -
(i) forms the principal elevation of the original dwellinghouse; or
(ii) fronts a highway and forms a side elevation of the original dwellinghouse
By 'original dwellinghouse', they mean the house as originally built, or as it stood in July 1948 if it was built before then. Even if a wall (or in your case the garage door) is set behind the main front of the house, it is still regarded as forming part of the principal (ie front) elevation.
The fact that it is just a roof is irrelevent - so far as the rules are concerned, it is an 'enlargement'.
If there was no original side garage, then the rules for side extensions come into play, and you can extend up to the front of the house
without planning permission in that case, as long as the width of the extension is not more than half the width of the original house.
Seems crazy but them's the rules.
Tony,
Thanks for the comprehensive reply, much appreciated (y)
Do you know if there is just one process for all planning applications or is there a quicker/simpler one for small changes such as this, as i would assume that it would be only my immediate neighbor that would be contacted as no one else is affected ?
Also, would BC need to be involved also please ?
So if your neighbour's window starts 900mm from the corner of their house the planners would have to consider your proposed roof extension would be blocking out light .
Thanks Leofric
Personally, i don't think that this will be a problem considering we are only looking to go out 1100mm and the size of their pillar before the window starts is 900mm
Also, my neighbors property is actually higher than us as our road is on a slope so my proposed roof would be visible at a height of 1.8m to them and they will simply see effectively just the height of a facia board and i propose a nice oak post to support that corner too with some greenery
The houses are North West facing too so it will not ever block sunlight
I have just checked our deeds and can see that there are a number of houses in our road where overhangs have been built over time, albeit, to the front of their adjoining neighbors house only (we are set forward of our neighbor hence our need for the 1100mm extension/green bit on my diagram)
So *assuming* that no one else went through planning permission for theirs (i cannot find any applications for those houses that have extended on the local planning portal), would that be a point for me to bring to the table and challenge planning on ?
Finally, can anyone confirm what the trigger is and dictates the need for BC to get involved please ?
As this is effectively a car port, i *think* that it is exempt from BC, correct ?
A conservatory, porch, covered yard, covered way or carport open on at least two sides and less than 30 sq m is exempt from building control.
Thanks Tony !
Size will be approx 2.4m x 3.4m with 1.1m of the 3.4m being open on the neighbors side so assuming this qualifies, yes (not the entirety being required) ?
Common sense would assume so.
With it being relatively short, you could argue that it is not a true carport in that the average family car wouldn't fit entirely under it (eg if you extended it to say 5m to make it a true carport, the majority of the side would be open anyway).
It's down to how an inspector views it, but I suspect most would be realistic.
