Hi all,
I'm a bit of novice so apologies if I use the wrong terminology!
I noticed the other day that the bottom bracket on the stair rail was loose. I unscrewed it and under the bracket a thick 1.5cm wedge of plaster was all broken and split. I removed all the loose plaster and it's taken it down to the breeze blocks on the house (see pic).
I obviously want this fixing so what would be the best material to use to fill the holes back in, make it level again and reattach the bracket. I suspect filler would be too weak?
Phil
Phil
