In recent weeks there have been several pleas for help from people who could not have a satisfactory shower because the water would go cold while they were showering.
This was reportedly caused by their boiler shutting down while the shower was running.
Some people on this forum gave the advice to run another hot tap while having a shower
This advice did enable some people to have a shower without the shower water going cold.
Others found only that the flow of water from the shower was reduced and the water still went cold.
The reason for the boiler shutting down is that the temperature of the incoming water supply is too high and the maximum flow rate of water available to the boiler is too low for the boiler at that incoming water temperature.
The flow of water through the boiler has to be sufficient to remove the heat produced at minimum modulation without the exit water temperature exceeding a safe maximum
If the flow of water is unable to remove that amount of heat then the boiler will shut down on overheat.
The amount of heat that the flow of water can remove from the boilers depends not only on the flow rate but also on the temperature of the incoming water supply.
This morning the temperature of the incoming water here is 20 deg C
