Removed wiring for ceiling rose to fit downlight..
I put all the live wire in one terminal strip, then did the same for the earth and neutral.. I extended the cable using 1mm two core and earth straight to my downlight
I turned on the electrics and it tripped...
Is it my dodgy wiring? Please be gentle guys
The previous installer simply wrapped/twisted the earth from the two cabled in ceiling rose together. Should I separate these?
And would it be better to use Wago 222 as opposed to these terminal strips?
Pic 1 - ceiling rose before work
Pic 2 - light switch
Pic 3 - Ceiling rose removed, wires put into terminal strip and 1mm 2 core plus earth added
Pic 4 - Down light wiring
And yes I will tidy up my wiring, encase and add earth sheathing
