Pan connector leaking
16 Jul 2009
Hull
If a toilet pan connector is leaking between the pan connector and toilet spigot. Would plumbers mate be an option to seal it? Or is this too much off a bodge?
Thanks was just seeing if I could get away without removing the toilet, with it being quiet old. Guess this isn't the case though.
Plumbers Mait has literally no uses for anything. I've owned a tub of it for five years and haven't once found the need for it. A leaking pan connector needs to be replaced, anything else is a temporary bodge
I once sealed a toilet with plumbers mait successfully.
For the life of me I couldn't find a pan connector seal to fit my old cast iron soil pipe diameter. I removed the rubber seal and wrapped a good sausage of mait around the plastic insert and shoved it into the soil pipe. Packed it out nice and tight with more mait and it never leaked once.
I eventually replaced the old stack with plastic.
A bodge yes but a successful bodge it was.
Maybe, but you were sealing the join between the pan connector and the soil pipe. This is a much easier joint to seal and was often done with mortar. The joint between the pan spigot and the pan connector is much more difficult.
I have successfully bodged with a neat bead of Fernox L S X ;)
Did you have to wait to set before testing?
No, it says to spray with water to speed curing - so i did . Then assuming the leak would have a similar effect inside, I just left it for a half hour and flushed.
