Detached garage conversion - my plans and some questions
6 Aug 2019
West Midlands
Hi all,
We have detached garage at the end of the garden with its own sloped drive way. We're looking to get started with a conversion in the coming weeks. I've confirmed with the council that it doesn't need any form of building notification as its under 30m2 and won't be used for habitable space and has no water line. It has a preinstalled 45amp supply which will be sufficient for our use as an office.
So it's a pitched roof structure and there's no boarding up to cover up the loft area, there are some family members wanting to retain this as an 'open ceiling' conversion so we'll completely see the rafters once done. It's a lot more work but open to hear any thoughts on this approach. The alternative would simply be the traditional boarding up to create a ceiling and an insulated loft area.
We will be getting large double french doors to replace the large garage door, this will help with getting some natural light in. I'm trying to get some second hand given the cost of these new.
First question is, how we would go about insulating the roof if we decide to opt for an open ceiling design. I know we will need to insulate between the joists, but wondering whether we need to put in any waterproofing membrane to start?
With the study walls what's the standard size batten that's used for the walls - we have a single brick construction so looking to get the building as well insulated as possible. I understand a membrane will need to be affixed to the wall first, but how is this affixed securely without compromising the membrane itself and what type would be needed?
There's a pillar that protrudes from the brick wall about 10cm I've considered to bring this wall's insulation to the same thickness so the pillar no longer protrudes. All other walls would be the standard cavity/insulation thickness, what ever that is.
Pictures would be good
Obviously better insulation if you fit a flat ceiling
However a mate converted a garage and we looked into (and dind't do ) a vaulted ceiling.
What we considered was creating a "fake" ceiling, actually two 45°corners and then a flat part higher up.
We were using rockwool. But if you used celotex or similar you could insulate the whole thing roughly as is, then add a structure that will take the weight of the new PB ceiling, adding more insulation once the PB is in situ.
Will try and get pictures, but I think the slud walling (size of battens used and insulation type) would be the same regardless?
I understand what you mean about the flat ceiling a bit higher up. I think I need to take a look at how the rafters are positioned to see if it would be feasible (and also look nice). But it sounds like it might take even more effort trying to create another flat ceiling higher up than trying to insulate and board up an open ceiling as the structure is already there to be insulated and boarded.
Can I get any suggestions for the wall membrane and how this is normally affixed to the wall?
It's also a single wall construction, wondering whether any foil based board will be needed when erecting the stud walls.
Pictures are on the way. Not at home at the moment so had to request them.
But aside from the open roof query, regarding the wall membrane how is this normally affixed to the wall itself - is it the battens which are screwed into the wall, do they hold it in position?
Good introductory video, thanks for that.
Is it also possible to tack the membrane directly to the wall, and fixing in the studs as you go along to the shape of the wall (instead of building the structure beforehand)?
So here are the internal and external images.
I'm confused. You say it won't be used as a habitable space.
So why the insulation and french doors?
Given it’s a trussed roof I don’t think you can do anything with that without major alterations or you’ll weaken the structure
It won't be used for sleeping accommodation, just as an office.
What about if we lined the inner part of the roof with a membrane, insulated between the studs in the usual way and then plasterboarded over it (leaving the other truss beams as they are).
For goodness sake fix a plasterboard ceiling - it's a pig ugly truss roof! Besides it is lined with non-breathable membrane so (between rafter detail) insulating and venting is a non starter - unless you remove the roof tiles of course.
It's really not that ugly, which is why having an opened up ceiling could've been an option. But if lining it and insulation will cause issues then we might just have to have a normal ceiling.
Can I can any suggestions on what membrane I need to use on the walls and floor? Perhaps with an example link to one
