- Joined
- 27 Jan 2008
- Messages
- 28,395
- Reaction score
- 3,452
- Location
- Country
The standard light switch and also for that matter the standard RCBO/MCB don't isolate as they don't switch the neutral, however in the main they are good enough to ensure the bulb has no line parts when renewing them, so if switched off at the wall light switch even one of the cob bulbs with exposed line wires would not give you a shock even if the earth/neutral could trip a RCD.
However that is not the case with electronic switches, some current is required to work the switch, as to if this is dangerous, or better or worse to a standard switch I don't know, hence the thread.
I know with a smart switch in my case Energenie if I remove the bulb it auto switches off, so that may be safer, how ever never tested to see if there is a voltage at the bulb holder with bulb removed.
With the socket also remove power to socket, and when power is returned the socket is off, again not tested if any voltage when socket switched off.
However the timers will still switch on at the pre-set time, so the lamp could switch on while your changing it.
I am about to fit more smart light switches and sockets mainly so we can switch on lights before leaving car to see way to house, the PIR switches off the lights before I am in house, and since I reverse up drive, the car does not trigger lights, so smart switch means I can switch them on and they will stay on.
Not really worried about safety as by end of this weekend all will be RCD protected, however just wondered about the whole idea of a socket that can be remotely switched on, it could have any item plugged in, in my case will be a standard lamp, but could be an electric drill or vacuum cleaner, I have used one with the AC plugged into it so I can cool down house before my return.
So what do you think about smart switches, are they safe? Could one have set one to switch on at 6 pm every night and forgot it was set to do it, and switched the vacuum off at the wall?
Thoughts please.
Thoughts please.
