Good afternoon all
We are having a house built, due for completion in December. Its not a DIY design one, but a new build from a typical national builder.
I have been asked to provide any electrical requests prior to work starting on the interior.
The main bathroom comes with a suite pre-specced and makes no provision for a cabinet above the sink or its associated lighting.
Crucially important to the issue is that the builder will not fit any equipment away from the standard spec or anything I free issue to them, meaning I must fit the cabinet and light after completion which is post NHBC inspection.
We have opted for full height tiling and ive mentioned to them that I will need electrics provided in there and naturally do not want to strip off a wall of new tiles. The suggestion they have made is a fused spur as part of my electrical options.
In terms of installation, does anyone know how exactly that will work ? as I have to specify the height of the spur and its location. Without being a sparky, all I can really specify is the position of the cabinet and light but I cannot figure out how it will pass the inspection. I didn't think you were allowed the fused spur to be in the bathroom itself (similar to fan switches being outside) but alternatively, a cable hanging out the wall also wont pass an inspection I would have thought.
The cabinet have only minimal clearance behind it for a cable but would not house a wall plate without cutting & if the wallplate was on the outside of the cabinet, I would not be able to take the output from the plate to the light without either it being visible outside the wall or removing tiles to feed it back inside to behind the cabinet.
Any thoughts or suggestions would be greatly appreciated.
