I am replacing a window with a patio door of the same width. The cut out has been done and I am now preparing the opening for the new triple glazed door. As it will be very heavy and with a low level aluminium threshold, I want to have the threshold substrate prepared and completely level and flat in advance. The positioning of the door is defined by the corner post and the depth of the door (145mm), which means it will sit directly above the original cavity. What I have done is taken the wall down to ground level, filled the bottom of the cavity with concrete to get a sold base, then built back up with one course of aerated 3.6N block a little deeper than the door.
I need to go up about 50mm more and so far considered two options. One is compacfoam, which would give me insulation under the threshold to avoid a cold bridge. This is v expensive, and the other issue is that I can't get it in the right size, so I would have to cut it and this is probably not going to help with a flat and stable base. The other is a strip of treated timber, which would be cheap and easy to source at the right width and depth, but wouldn't have the insulating qualities of compacfoam.
Are there any alternative options I have not considered?
Thanks.
Thanks.
