We have a conventional boiler system, small tank in the loft, hot water cylinder in upstairs cupboard with pump and Y port valve and boiler downstairs.
Earlier this year had new timer / control unit fitted, new Y port valve, new pump and new hot water thermostat.
Since the beginning of this week the hot water coming on at 5am has made a repeated knocking / tapping sound, starts fairly slow, gets faster, then slows and stops. Sounds to me like pipe expansion against joists or something in the floor. Knocking noise probably lasts 15 seconds in total.
However, it doesn't stop when up to temperature. The noise just repeats every minute or so and it's driving me mad!
Is it pipe expansion or could it be something else? Anything else I can try?
We have a magnaclean fitted above the boiler, I noticed that sounded like running water (air in system?), I got some air out last night but its made no difference. If anything, worse this morning.
