I have a unvented CH & HW system
Boiler is Ideal Classic FF260.
The whole CH and HW system has been working fine, both activating and deactivating on timed control and through room thermostat. I now have an intermittent issue where both HW and CH can be off on the timing programmer and yet the pump remains on. The only way I can stop the pump is to turn off all power to CH system. It usually resets, to function normally after 12+ hours with no power.
I have replaced the CH Timing programmer and has made no change.
Can anyone please offer any guidance to identify what is causing the issue and if its a simple part replacement?
P.S. I have read other threads which suggest it might be either the HW or CH actuator being faulty. But I do not know if this is the case.
One is a 2 port Sunvic LSZ2301 in a plastic case and the other a Honeywell V4043H1056 2 Port motorized valve in a galvenised metal case, but not aware which is HW or for CH.
