Logs in log store have mould
17 May 2013
I built what I think is a pretty good log store about a year ago and stocked it up after reading about airflow and so on.
Started using it recently with logs that have been seasoning all summer and were nice and clean to start with. As I get under the first couple of rows there is quite a bit of surface mould.
The logs actually burn ok so is this just something that happens in damp months?I have a lot of wood stored here and am kind of relying on being able to use it!
d000hg, good evening.
OK surface mould on dead timber will occur, that is what happens at this time of year, mushrooms Etc.
So long as the mould is on the surface then no serious problems, this is a natural process the important bit is that the logs still burn well, because the mould has not had enough time to "get in-to" the logs themselves
I have burned "dry" but rotted wood, actually quite well?? more air and faster combustion????
Ken.
Good to know, thanks. It's just concerning to find wood that should be seasoned and appears damp.
So here are photos progressively zooming in. It's the round logs I'm having issues with, next to the orange bag, the others seem ok.
They look great until you get up close.
I've got one of those.
This was designed so there's is ventilation on literally every side, including underneath and at the back. It's located in a place that gets a fair amount of sun and is exposed to wind... And I tried to stack logs so there are gaps between them.
How would I add more ventilation still?
Could it be that (from the photos) the logs with the mould problem are exposed to the elements more than the other ones as the roof in that area doesn't seem to cover the whole log store area?
Very difficult to ventilate more.....the outer logs are getting sunlight which mould spores don't like. I don't think you can do much about it apart from shifting the logs round a bit which is a bore.
Are the mouldy logs below 15% moisture?
John :)
You could do with more roof overhang , looks like it wouldn't take much for the outside logs to get soaked?
John :)
20% moisture is allegedly the optimum.
Ah right.....my own moisture meter (hitachi) shows a green light at around 15, amber at 20 and red at 25+.......no idea how accurate it is, of course.
Logs in a stack should get to around the 15% mark if the rain can't get to them.
John :)
