Having different Pyronix set timers?
16 Nov 2017
Is it possible to have different arming times for different inputs?
What I mean is if someone sets using a tag can the timer be set to say 30 seconds so they can get out of the property in time, but if setting the alarm using a keyfob can the timer be shortened to say 5 seconds?
Reason I ask is if I set me alarm going to bed I need to listen to the annoying high pitched tone for about 20 seconds and would be great if it just beeped to say it was set.
Thanks.
You can per area ....normally I set for example B night set ( with silent set just bleep at the end ) you can have a different setting time PER area for app setting
Managed to get it done so thanks.
When I was programming the keyfobs I also noticed that I can't set the panic alarm function. Is there a setting that needs to be set to allow this?
How did you set the silent set modes
Need to make sure you have the keyfob buttons set to what area you want say B, if using fobs. If not just set the different areas for the keypad. and then volume settings set to 1 instead of 2 and it will just chime when set, 2 does a beeping and 0 does nothing.
By default ....panic is set on the key fob UNLESS ....you have been playing in the menus !
Yes playing in the menus as it's a DIY setup.
It's not a choice when programming the buttons.
Is there something that could stop that selection?
