Having different Pyronix set timers?
Discussion in 'Alarms, CCTV & Telephones' started by dg_pug106gti, 30 Oct 2019.
  1. dg_pug106gti
    dg_pug106gti
    16 Nov 2017
    69
    Thanks Received:
    Country:
    Is it possible to have different arming times for different inputs?
    What I mean is if someone sets using a tag can the timer be set to say 30 seconds so they can get out of the property in time, but if setting the alarm using a keyfob can the timer be shortened to say 5 seconds?
    Reason I ask is if I set me alarm going to bed I need to listen to the annoying high pitched tone for about 20 seconds and would be great if it just beeped to say it was set.
    Thanks.
  2. Sponsored Links
  3. sparkymarka
    sparkymarka
    16 Feb 2011
    9,033
    Thanks Received:
    1,381
    Sheffield
    Country:
    You can per area ....normally I set for example B night set ( with silent set just bleep at the end ) you can have a different setting time PER area for app setting
    • Like Like x 1
  4. Rustynut
    Rustynut
    10 Feb 2019
    85
    Thanks Received:
    3
    Country:
    I like the sound of that for the night setting.
  5. dg_pug106gti
    dg_pug106gti
    16 Nov 2017
    69
    Thanks Received:
    Country:
    Managed to get it done so thanks.
    When I was programming the keyfobs I also noticed that I can't set the panic alarm function. Is there a setting that needs to be set to allow this?
  6. Rustynut
    Rustynut
    10 Feb 2019
    85
    Thanks Received:
    3
    Country:
    How did you set the silent set modes
  7. dg_pug106gti
    dg_pug106gti
    16 Nov 2017
    69
    Thanks Received:
    Country:
    Need to make sure you have the keyfob buttons set to what area you want say B, if using fobs. If not just set the different areas for the keypad. and then volume settings set to 1 instead of 2 and it will just chime when set, 2 does a beeping and 0 does nothing.
    • Like Like x 1
  8. Sponsored Links
  9. sparkymarka
    sparkymarka
    16 Feb 2011
    9,033
    Thanks Received:
    1,381
    Sheffield
    Country:
    By default ....panic is set on the key fob UNLESS ....you have been playing in the menus !
  10. dg_pug106gti
    dg_pug106gti
    16 Nov 2017
    69
    Thanks Received:
    Country:
    Yes playing in the menus as it's a DIY setup.
    It's not a choice when programming the buttons.
    Is there something that could stop that selection?
  11. sparkymarka
    sparkymarka
    16 Feb 2011
    9,033
    Thanks Received:
    1,381
    Sheffield
    Country:
    Errr your fingers ? ....lol...
  12. dg_pug106gti
    dg_pug106gti
    16 Nov 2017
    69
    Thanks Received:
    Country:
    Very good, lol.
  13. dg_pug106gti
    dg_pug106gti
    16 Nov 2017
    69
    Thanks Received:
    Country:
    What could my fat fingers have adjusted that would remove the panic hold up selection from being an option when assigning buttons to the keyfobs?
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
