Hi all,
Please forgive any nonsense from me as I don't know much about heating systems.
Myself and my partner moved into a new build home back in Christmas 2016 and we've always had issues with getting the digital thermostat system to play ball and control our heating as we expect it to.
It's a two bedroom end-terrace with a Vaillant combi boiler and two Danfoss TP5000 Si (mains, not battery) thermostats, one upstairs in the master bedroom and the other downstairs in the small entrance hall.
My understanding is that if I set my downstairs stat to 23C, it should kick the boiler in to maintain that temperature. Once the stat sees the room at 23C it shuts the central heating off. Rinse, repeat.
Trouble is, the entrance hall gets hot very quickly, especially as it is joined to our kitchen so cooker, oven, tumble dryer frequently adding heat to the area.
We have always found that the thermostat knocks the heating off very prematurely while we are freezing our proverbials off in the living room, which is quite a large space and also includes the stairs.
The only way we have managed to overcome this is by setting the thermostat to something ridiculous like 29C just to keep the heating on so that the radiator in the living room has a chance to do its thing.
I have also always found the thermostats very inaccurate and read a few degrees above what the room temperature in the hall actually is.
Today, I placed a separate room thermometer in the hall and checked it a few hours later.
It read the temperature in the hall as just over 19C.
However, the room temperature displayed on the thermostat was 23C.
I have already set the temperature bias function to -1.5C so it used to be even worse than that!
Can anybody who knows their heating systems offer up any advice?
I am considering purchasing the optional TS2 temperature sensor and siting it in the living room so it more accurately controls the heating system based on the room we spend the most time in.
My next trick is to actually turn the radiator off in the hall, so that it doesn't heat up so quickly as to knock the heating off prematurely. Probably frowned upon but it's getting frustrating now.
