Halogen and LEDs both 50w or equivalent
There is a transformer for each fitting, led bulb 8w
Winston , so the black one is 20-60w and looks like white one 10- 60w?
It will likely work with 2 off each white electronic transformer, however normal limit with electronic transformers is 1 meter of cable,
Look at the pictures again, one states AC, the other has the ~ mark which means AC. The limit of 1 meter is not because of volt drop, it is because at the frequency used to reduce the transformer size long leads will radiate power.They will run happily on the DC outputs of his present PSU's, they are not high frequency output, but DC - a rather raw DC but none the less DC. The HF is limited to inside those SMPSU's. As I said, just one of his PSU's is adequate to supply all six of his new LED lamps.
Yes one of the existing power supplies will just supply the 6 x 10W LED bulbs, and will likely work without any problem, however that involves crossings ones fingers,
