Wet UFH - insulation advice
Out of interest - how long to break it up and remove the floor?
That’s where the majority of the cost is, so was thinking I could do it myself.
Bought myself a £99 Toolstation breaker, and broke up 110m2 of 200mm concrete in my front garden. Took me 3 days. Yours may take the same amount of time as you would have to barrow the rubble to a skip.
It's not all about payback!
You will also be "enjoying" the benefits of the home improvement... evenly heated space, freeing up walls from rads etc.
This is also true. Think I may rent a breaker for a week for £50, order a skip and get on with it.
The only way to get it done is to get it done (y)
Rustle up a couple of bored teenagers to do the barrowing for you @£40 each per day ;)
I’ve got a few mates who’ll work for a few beers in the evening, so that’s good. I just need to be prepared to barrow 6 tons of concrete from their houses if the need were to ever arise...
Last year, 3 of us worked till 3am laying UFH in two new builds as screeders were coming later that morning... They didn't turn up until 3 days later... Never again! :mad:
If you were in Barnet and not Bristol, I might be tempted :)
Hah. I have time on my side - limited only by how long I can put up with 44square meters of my house being unheated. Not long is the answer in this weather...
Did somebody force you to do it this time of year? :LOL:
Ah! So you don't have time on your side then! :whistle:
She pushed through the knocking down of the walls / putting in the steels.
I’m reserving time to make sure it’s heated properly and finished to a high standard.
She’s more interested in granite v. Silstone worktops...
Whether you have underfloor heating or not, insulated floors make a much more cosy home than just cold concrete.
Bear in mind you will need to dig up not just the floor, but a bit of soil too. You need type 1, sand blinding, dpm, concrete slab, insulation, screed.
Breaking up the concrete itself isnt too bad, its probably a couple of days work for 1man. Another day or so for the reduced dig.
If you have room you might want a grab lorry instead of a skip -it might work out dearer than a skip for the quantity if you only need one skip, but you havent got to load a skip. Or get a low skip, or one with a door. Running up a scaffold plank into a skip is quite hard.
Id be guessing at 2no 8 yard skips if you dig out 300mm or so.....in which case a grab will be best.
And you need a whacker plate for the type 1 as its needs compacting.
In terms of underfloor heating, I found a plumber who did it for a labour price and I supplied the underfloor heating kit. Underfloor heating firms can charge an awful lot for supply and install.
